Since the Raspberry GPIO only support 3.3V and the Sainsmart relay module need 5V to switch the relay I used a ULN2803A and an external power supply (the same I use to power the Raspberry PI, since it supports more then enough amps) to operate the optical switches and protect the Raspberries GPIO.
To run a test on the whole thing I put together a small Python script.
Python Script:
import RPi.GPIO as gpio
import time
# peter ports = [6,12,13,19,16,26,20,21]
# port list
# GPIO-6 ==> relay 1
# GPIO-12 ==> relay 2
# GPIO-13 ==> relay 3
# GPIO-19 ==> relay 4
# GPIO-16 ==> relay 5
# GPIO-26 ==> relay 6
# GPIO-20 ==> relay 7
# GPIO-21 ==> relay 8
#set pins to BCM mode
gpio.setmode(gpio.BCM)
#setup all pins for output
for port in ports:
gpio.setup(port, gpio.OUT)
#set all pins to high (relay close NO, open NC)
print("high")
for port in ports:
gpio.output(port, gpio.HIGH)
time.sleep(3)
#set alls pins to low (relay open NO, close NC)
print("low")
for port in ports:
gpio.output(port, gpio.LOW)
# free gpio pins
gpio.cleanup()
Richard Deininger
