Humidity and Temperature sensor with WEB log
This is an humidity and temperature sensor created using an Arduino Uno, a DHT11 sensor and the Ethernet shield to log data to a WEB Page.
Used to monitor a Cigar Humidor. Details of construction, code and parts here: http://www.cava.cuadratic.com/
LabelPart TypeProperties
LCD1LCD screenTipo Character; pins 16
LED1Red LED - 5mmpaquete 5 mm [THT]; leg yes; Color Red (633nm)
Parte1Arduino Uno (Rev3)Tipo Arduino UNO (Rev3)
Parte2Arduino Ethernet Shield (Rev3)Tipo Ethernet Shield (Rev3)
R1Rotary Potentiometer (Small)paquete THT; tamaño Rotary - 9mm; track Linear; Tipo Rotary Shaft Potentiometer; máxima resistencia 10kΩ
R2220 Ω Resistorpaquete THT; tolerance ±5%; bands 4; Resistencia 220Ω; espacio entre pines 400 mil
R3220 Ω Resistorpaquete THT; tolerance ±5%; bands 4; Resistencia 220Ω; espacio entre pines 400 mil
RHT1Humidity and Temperature Sensor RHT03sensing element Polymer humidity capacitor; power supply 3.3-5.5V DC; output signal Digital Signal
View project log
Jasmine Brackett wrote 08/07/2014 at 19:45 • point
Hello valencia.ca, just thought I'd let you know that you need to add a few more details to your project to give it the best chance of going through to the next round of The Hackaday Prize.
By August 20th you must have the following:
- A video. It should be less than 2 minutes long describing your project. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
There are a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
load.nikon wrote 04/03/2014 at 08:39 • point
Think you could fit a dozen temperature/humidity sensors inside of ping pong balls and have data transmit within about 3 feet, then display on a web interface?
valencia.ca wrote 04/03/2014 at 13:11 • point
I guess that is possible but not with these sensors. The DHT11 requires a signal from the Arduino and, at some point, there is a two way communication. I think a sensor with embedded bluetooth capabilities is what you need but I am not aware of any at this point. Please also notice that if the sensor is inside the ball, the accuracy of the measures will be affected.
