Finally I Have a Character ROM Code
A project log for TRS-80 Compatible Clone
A TRS-80 using more modern parts
hacker404Hacker404 • 05/31/2015 at 12:10•1 Comment
Here's what it looks like -
The above is what it will look like on a standard 4:3 screen. The character are double spaced both horizontally and vertically.
I modified the characters so that the descenders drop further -
Below is a render of what it looks like in ROM (when it gets there).
And the code - Javascript format as I used Javascript to render it.
0x00,0x1F,0x11,0x11,0x11,0x11,0x11,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x10,0x10,0x10,0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x04,0x02,0x0F,0x04,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x11,0x1B,0x15,0x1B,0x11,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x02,0x14,0x18,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x1F,0x0A,0x0A,0x1B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x08,0x1E,0x09,0x05,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x02,0x1F,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x00,0x00,0x1F,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x04,0x15,0x0E,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x15,0x0E,0x04,0x15,0x0E,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x08,0x1F,0x08,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x1B,0x15,0x1B,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x15,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x11,0x11,0x1F,0x11,0x11,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x15,0x15,0x17,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x17,0x15,0x15,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x1D,0x15,0x15,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x15,0x15,0x1D,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x05,0x02,0x15,0x18,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x0A,0x0A,0x0A,0x0A,0x0A,0x1B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x11,0x0A,0x04,0x0A,0x11,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x0E,0x0E,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x10,0x08,0x04,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x1F,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x15,0x15,0x1D,0x11,0x11,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x11,0x11,0x1D,0x15,0x15,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x11,0x11,0x17,0x15,0x15,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x15,0x15,0x17,0x11,0x11,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x04,0x04,0x04,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0A,0x0A,0x0A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0A,0x0A,0x1F,0x0A,0x1F,0x0A,0x0A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x0F,0x14,0x0E,0x05,0x1E,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x18,0x19,0x02,0x04,0x08,0x13,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x14,0x14,0x08,0x15,0x12,0x0D,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0C,0x0C,0x08,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x04,0x08,0x08,0x08,0x04,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x04,0x02,0x02,0x02,0x04,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x15,0x0E,0x1F,0x0E,0x15,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x04,0x1F,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x0C,0x0C,0x08,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x13,0x15,0x19,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x0C,0x04,0x04,0x04,0x04,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x01,0x0E,0x10,0x10,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x01,0x06,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x06,0x0A,0x12,0x1F,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x10,0x1E,0x01,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x06,0x08,0x10,0x1E,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x01,0x02,0x04,0x08,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x0E,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x0F,0x01,0x02,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0C,0x0C,0x00,0x0C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0C,0x0C,0x00,0x0C,0x0C,0x08,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x04,0x08,0x10,0x08,0x04,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x04,0x02,0x01,0x02,0x04,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x01,0x02,0x04,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x01,0x0D,0x15,0x15,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x0A,0x11,0x11,0x1F,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1E,0x09,0x09,0x0E,0x09,0x09,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x10,0x10,0x10,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1E,0x09,0x09,0x09,0x09,0x09,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x10,0x10,0x1C,0x10,0x10,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x10,0x10,0x1C,0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0F,0x10,0x10,0x13,0x11,0x11,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x11,0x1F,0x11,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x04,0x04,0x04,0x04,0x04,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x01,0x01,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x12,0x14,0x18,0x14,0x12,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x1B,0x15,0x15,0x11,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x19,0x15,0x13,0x11,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x11,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1E,0x11,0x11,0x1E,0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x11,0x11,0x15,0x12,0x0D,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1E,0x11,0x11,0x1E,0x14,0x12,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0E,0x11,0x10,0x0E,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x11,0x11,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x11,0x0A,0x0A,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x11,0x11,0x15,0x1B,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x0A,0x04,0x0A,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x0A,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x1F,0x01,0x02,0x04,0x08,0x10,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x0E,0x15,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x04,0x04,0x15,0x0E,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x06,0x06,0x04,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0x01,0x0F,0x11,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x10,0x10,0x16,0x19,0x11,0x19,0x16,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0x11,0x10,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x0D,0x13,0x11,0x13,0x0D,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0x11,0x1F,0x10,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x05,0x04,0x0E,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0D,0x13,0x13,0x0D,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x10,0x10,0x16,0x19,0x11,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x00,0x0C,0x04,0x04,0x04,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x00,0x01,0x01,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x10,0x10,0x12,0x14,0x18,0x14,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0C,0x04,0x04,0x04,0x04,0x04,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1A,0x15,0x15,0x15,0x15,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x16,0x19,0x11,0x11,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0x11,0x11,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x16,0x19,0x11,0x19,0x16,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0D,0x13,0x11,0x13,0x0D,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x16,0x19,0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0F,0x10,0x0E,0x01,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x1F,0x04,0x04,0x05,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x11,0x11,0x11,0x13,0x0D,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x11,0x11,0x11,0x0A,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x11,0x11,0x15,0x15,0x0A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x11,0x0A,0x04,0x0A,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x11,0x11,0x11,0x0F,0x01,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0x02,0x04,0x08,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x04,0x04,0x08,0x04,0x04,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x04,0x00,0x04,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x04,0x04,0x02,0x04,0x04,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x15,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0A,0x15,0x0A,0x15,0x0A,0x15,0x0A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x07,0x07,0x07,0x07,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x38,0x38,0x38,0x38,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,
That's it for today!
magiclant3rn wrote 06/04/2015 at 17:56 • point
Lowercase letters were not available on the Model I regardless of which ROMs were used. They may have been defined in the ROM, but were not displayable because they only installed enough static RAMs to support the uppercase alphabet. Instead of eight static RAMs for eight bits, they installed fewer to cut cost. A workaround was to solder an additional static RAM piggy backed onto an existing one, bending up the address and data pins and connecting those with jumper wires to the bus. Then you had to load a driver. A toggle switch was sometimes installed to disable the mod when the driver wasn't loaded.
