24 GHz modification of a radar module for our BabyEMdrive.
I removed the patch antenna connection to the via and soldered an antenna connector.
The freakin expensive blue cable can deliver up to 26 GHz with low loss.
Signal on the Osci: Doppler frequency from the mixer output
