#EMDrive test with dielectric.
Last night was very quiet, the test is very low noise as you can see in the smooth oscillations of the platform. It does not happen often to get these conditions. Unfortunately I was stupid and didn´t plug in the charger for the notebook, so I recorded just one period. Anyway, another day another try.
But look at this curve - hope it will look like this every time :)
You can download the data (dielectric02BR.emd) and an improved viewer for windows here: goo.gl/ylD5kY
You can select several different sensors like temperature,PA_current, phase, frequency to compare them with the displacement graph.
