There´s a lot of work to do to build up a new test rig.
This board generates 5V/600mA from a 3.7V Li-Ion battery to drive the RF generator and the endplate servo.
It has a microcontroller to drive up to three servos - of which we need one for the endplate and optionally one for the antenna position. It allows an analog servo to be driven with a 32bit timer accuracy.
