Jo is milling the housing/radiator for our new RF source.
We´ll have a heat dissipation of about 2 Watt, and we need a proper shielding, so a good housing is mandatory. You can burn your fingers on the ICs at nominal parameters (500mW output @ 24 GHz)
Update: Jo finished the housing/heatsink
Did you consider watercooling? You can get yourself a cooler master kit for a pc for a mere 60 $. You can attach that to the panel..
You can use thermal grease too.
