The interferometer setup is ready for testing the Baby EMdrive.
Hardware and Software are running. We are excited to make some measurements.
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
Can't wait to see the results. maybe in a excel sheet?
I will provide the software (as seen in the Semifinals video) and the files for downloading, so you can zoom around in the graph. I´ll add an export function when I got some more time, so you can get the values in CSV format.
when can we see the results?
I´m working on it. It´s only possible to get a stable interference pattern after 11pm when no one is running around in the building. I figured out how to make a good pattern and was running a few quick frequency sweeps.
I had to calibrate the power amplifier and measure the SWR.
Without clean measurements there won´t be any values, so I first take care of setting up everything correctly.
If everything works well, they will be available this week.
Very cool! Looks like you're gearing up for some serious science!
It could only become better :)
how long will each measurement session take?
30mins to 2 hours. First we will only drive frequency sweeps and see if the two feedback values show resonance and if some thrust occurs. If so, we will focus on these frequencies and try on/off toggle cycles in both directions.
