Here are the latests tests with modified amplifier bias.
The marked peaks occur at about 24050 MHz, near the designed resonance frequency of 24100 MHz.
They show in the predicted direction: Big end leading, turning the platform clockwise/counterclockwise depending on the cavity´s orientation on the platform.
Orange line is the trendline. Temperature changes over several hours of measurements at night are causing a drift - just for better visualization
