OpenLoad - DC Electronic Load
A DC Electronic load for PSU/battery testing and efficiency evaluation.
The project is in its begging, the plan is to build a electronic load to evaluate PSUs and, if possible, help to design more efficient ones. The electronic load should be able to hold at least 100W, providing in a display or via PC interface the following parameters: Set current/voltage/power, actual current/voltage/power, it will be cool if i can implement some efficiency calculations to it and graph all the acquired data.
Clovis Fritzen wrote 05/07/2015 at 01:37 • point
Hey Jean, how are you?
I have made something similar during my summer internship @ UBC Vancouver (Canada); what is have done is exactly this: http://electronics.stackexchange.com/questions/129609/how-does-this-constant-current-sink-actually-work
and it worked pretty well for DC references but not so well for frequencies of more than some hundreds of hertz (due to low gain opamps and high mosfet capacitances). I was able to control the dissipation of 250W with these heatsinks:
add me back on hackaday so that we can talk more, if you wish so.
Jean Mazurkievicz wrote 05/07/2015 at 17:38 • point
Hello Clovis, i'm fine, what about you?
Thanks for the heat sink recommendation,  i will probably increase the power capacity once i have a working controller. Which opamp/mosfet combination did you use?
texane wrote 05/08/2015 at 02:21 • point
Hi both of you,
I recently needed such electronics and ended writing this:
http://www.embeddedrelated.com/showarticle/775.php
Regarding the amplifer, an AD8552 is used for its very low
voltage offset, allowing for low load currents to be set. For
the transistor, a BTS117 is used.
The voltage sense does not exist, so I am very interested
about your controller.
Cheers
