Train Disruption Indicator
Tube / Train Disruption Indicator with a Blinky Tape RGB LED Strip and Raspberry Pi
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Having been inspired by a Blinky Tape blog post by the FT engineering team I thought I’d try to use mine to display some useful information. In this case how the trains and tube are running. So I’ve come up with a couple of python scripts (tested on a Raspberry Pi B+ but should work on other systems if you change the serial port name from /dev/ttyACM0).
London Underground line status
Main line train station delays
