The rudder will be controlled by a HS-485HB servo. The rudder's shaft is rounded so I've sanded down on one side. Then I 3D printed a small something (help me with the name please) to attache to the shaft. The plate of this something and the plate of the servo are connected with not-so-precise rods. It works. Yet.
