You need to modify the Adafruit_SI1145 library as follows (or just substitute tthe SI1145 for the SI1132):
edit Adafruit_SI1145.cpp
#include "Adafruit_SI1145.h"
Adafruit_SI1145::Adafruit_SI1145() {
_addr = SI1145_ADDR;
boolean Adafruit_SI1145::begin(void) {
Wire.begin();
uint8_t id = read8(SI1145_REG_PARTID);
// if (id != 0x45) return false; // look for SI1145
if ((id != 0x32) && (id != 0x45)) return false; // look for SI1132 or SI1145
