I'll have all the codes up on github after launch, but this is what the running firing sequence looks like this (the interval between firings was switched from seconds to milliseconds to make the video shorter)
A project log for 256 Channel Firework Controller
Use two cheap 16-relay boards to multiplex and remotely control up to 256 channels of firey madness
