The CNC Parts are back from the shop, and they are awesome!
I had to wait two weeks for them, but it was worth it. Next step will be sanding and anodising the parts. I think this is necessary to prevent corrosion, but also to achieve a harder Surface for the tool changer.
X-Axis/Extruder and the mastercooler which will cool the direct drive extruder directly and the tools indirectly
i wanted to use compression fittings known from PC watercool systems. They turned out to be way too heavy so i swapped them with PE fittings used in the chemical industry.
While i waited for the tools to be machined i worked on how the hoses are guided along the energy chain.
Z-Axis is also on a good way, the tension mechanism is ready, just a few brackets left to do.
