Everything set!
A project log for Blackbox - Tool Changing 3D Printer
high-end open-source printer with a water-cooled tool changer.
marc-schmannMarc Schömann 05/21/2018 at 16:060 Comments
So i collected all parts and assembled the modules as far as possible. I began to disassemble the old Iteration today and if everything runs smoothly i should at least be able to assemble the XY-Axis today.
The XY-Axis is complete, you can see the new fancy SLS printed fanducts here, the just slide in. Cabling was a mess, i need to enlarge the cable channels big time.
