Date: ~December 2015
When we first moved into our new home, the curtain rod and hardware for the narrow window near the front door was missing. My wife tasked me with fixing this. The result was a wooden dowel (painted black), two simple brackets to hold the rod up, and two very special finials on either end.
For the finials, I took a picture of my daughter's profile in front of a bright background, traced the image in Inkscape, and used the rotate extrude function in OpenSCAD to make it a solid. If you tilt your head, you may be able to make out her profile.
MakerBlock
