Date: ~December 2015
We discovered the closet door guides in our new home were all either damaged or missing. Tasked with fixing them, I grabbed my trusty calipers and whipped up some closet guides of our very own.
These are pretty simple in design - basically a letter "E". The only trick to these was making sure there was enough clearance for the doors to slide smoothly on either side. Installing was a snap. I cleaned the floor thoroughly with some floor cleaner, then added some glue dots which kept them in place. One for one bedroom, two more in the master bedroom.
MakerBlock
