Stemming from a school project, this project further develops the idea of a low cost and portable glovebox
an inexpensive and portable glove box for use in areas where cost is a very big problem
An idea came to me. Using a teensy board and various environmental sensors, the inside of the box could be monitored. This monitoring could be used to help the user identify any threat posed by the sample in the box or just monitor the general conditions in the box such as temperature or humidity.
I'm not familiar with gloveboxes outside a car, could you please explain what this does and why. I'm not trying to be negative about your project, but my background is far removed from the biotech engineering world and I'd like to learn something. It's not clear to me why you need to monitor the temp and humidity or identify threats inside a box holding gloves (if it does hold gloves).
It's a sealed box with inward-pointing gloves attached to holes in the walls. A researcher sticks his hands in the gloves to manipulate things in the box.
The box can contain potentially dangerous stuff (biologicals, poisonout chemicals), or can just contain stuff you don't want contaminated from the outside air (Nitrogen atmosphere, archaeological samples, moon rocks).
Googling "glove box" in the image search will show you lots of examples.
