The two modules arrived and I assembled the DS1307 RTC kit. The basic code for generating the "poems" is working (still on the Pro Mini). I attempted to compile it for the Teensy-LC but got an error related to the library I'm using for the seven segment display and a warning related to using an array of strings. I'm debating whether to figure these issues out now before proceeding with the Teensy-LC or if I should continue with the Pro Mini and then adapt for the LC later. Any ideas of alternative ways to handle the seven segment display on the Teensy?
