It's right here!
This release is pretty significant. I am preparing to shift from the oft-repeated arduous process of hand-soldering modules... to creating printed circuit boards. I wanted to have the specs for the major connectors (DE-9, DA-15, DB-25, etc.) firm before moving forward with any production runs.
The key things that have changed:
- DA-15 is now an Enhanced Battery Connector.
- LiPo batteries already have a balance connector. Why use an EBC instead?
- Pretty much all balance connectors in the RC industry merely allow a battery charger to monitor two or more cells of a battery pack with an unknown chemical composition. The EBC spec supports battery packs with 6 cells (e.g. 6S) & includes one id pin. This pin has a resistor connected which can be used to identify both how many cells are in the pack, and what their chemical composition is. For instance, a 4S LiPo could have a simple 1.3Kohm resistor embedded within. Off-the-shelf battery chargers could include new functionality that analyzes the resistor value of the battery pack, compares it to the matrix & pre-loads the best settings for charging the pack.
- LiPo batteries are already too heavy. Why add a heavy old-school DA-15 connector?
- You don't have to! You can use a 16 contact socket IDC header instead. All 16 contacts are only really necessary on a fully-equipped 6S battery pack. A 3S pack would still use the 16 contact socket IDC header, but could terminate as few as four wires on said header.
- Why not smaller?
- There's nothing that would prevent use of a smaller connector. It seems, however, that good-ol' 2.54mm headers are best suited for external battery management, and 16 contacts seems to provide just enough functionality & flexibility.
- Why no digital communication?
- There is! I was able to squeeze in `one-wire-data` on contact 1. This digital bus allows one to embed inexpensive digital temperature sensors & similar into the pack.
- Why support only LiPo?
- They support more! Enhanced Battery Connectors support Pb (lead acid), NiMH, LiIo & LiFe batteries as well! As seen on the matrix.
- DC-37 is now 'The High-Def D-Sub'.
- The connector now is spec'd to support HDBaseT (1080, 4K, etc), USB3, & standard BaseT connections. Example: "6x Raspi's and/or 6x Nvidia Jetsons sharing a backplane."
- Most connectors now support up to 40VDC.
- Why so high?
- 24V battery systems (such as those in some RVs) may reach voltages as high as 36V while charging. I wanted Retro Modules to be compatible.
- A grid of 9x 18650's (a 3x3 9S battery pack) has a max safe voltage of 37.8VDC.
- While the average D-Sub contact can support up to 5A, D-Subs with IDC termination use wires that can only support about 1.2A each. An increase in the maximum supported voltage safely allows for more wattage on those same wires.
- Some module arrangements may have a common backplane, while some module arrangements may feature daisy-chaining. The higher voltage allowance helps reduce risk of connection-related power delivery issues.
- Why not higher?
- 40VDC is the maximum voltage supported by many inexpensive DC-DC buck converters that use the LM2596 (or similar) regulator.
- Voltages over 50V can be considered dangerous (hat tip to: @Njkotzur via https://hackaday.io/project/45999-dewalt-flexvolt-60v-battery-adapter/discussion-100764)
- Why so high?
- Many connectors now support (on a dedicated contact) voltages up to 15VDC.
- Why up to 15VDC?
- Smaller modules may not have any room for a beefy DC-DC buck converter. The lower voltage limit allows for simple linear regulators (etc) if needed.
- Smaller modules may not need much power at all.
- Many 12VDC automotive accessories are able to tolerate up to 15VDC.
- Why up to 15VDC?
- Some connectors now support 12VDC with the ability to request more.
- Why the complexity?
- There are many 12VDC automotive accessories (and similar) that prefer just that: about 12VDC. The connectors (such as `din5-240`, `din6-240` & `din8`) will provide about 12VDC by default if a suitable power source is available. Some devices, however, make do with 12VDC -- but work better with higher voltages if they are available. These connectors (much like functionality described in USB-C PD documentation) are able to provide more power if a source can provide it & the client device requests it.
This spec is becoming easier & easier to work with. I'm now able to manually make one or two modules in an evening with great ease. I'll be posting a few new (related) projects soon!
