Here are a number of the Retro Modules I've been working on as I've been fleshing out the spec. This video demonstrates some of the possibilities provided via this framework. In building the modules, I discovered pros & cons of varying connector specifications. As things became more stable, I found I was able to deploy quite a few modules around the house, shop & truck. Just the beginning...
