Smart Open Automation Project
I'll use a ATSAMR21G18A for the RF section of this project
In the endI still use Eagle...
So i've started drawing the PCB shape for the Phoenix ME-IO housing
I'm facing a little delay on the project because i'd like to try the new Altium Circuit maker for the PCB designing.
Another issue is the form factor.... i'd like to use the Phoenix ME-IO housing, but it's not really cheap ...
View all 3 project logs
Why not create an open source form factor that is compatible with the Phoenix ME-IO? I ask from ignorance as I have done zero research into this possibility.
Tommy Falgout
Debanshu
8BitsAndAByte
sjm4306
Yes, delete it Cancel
You are about to report the project "S.O.A.P.", please tell us the reason.
