Eagle Files in Github
A project log for ESP8266-01 Breakout
Cool little ESP8266 Breakout Board / Flasher for NodeMCU
technolomaniactechnolomaniac • 05/12/2015 at 23:57•1 Comment
Check out the repo linked to this project for the files including a modified LM1117 that looks nicer and the proper push buttons. Libraries for both are included in the repo. Look here: https://github.com/sfgit/ESP8266-01-BREAKOUT
Lucas Rangit MAGASWERAN wrote 05/13/2015 at 03:50 • point
Thanks Matt. I wanted to use the DRC (Design Rules Check) so I had to change the package to fix the overlapping. I ended up finding a vertical TO-220 package of the LM1117T-3.3 regulator at v-reg.LM317TS. Would this work? I got prompted to "Add a technology" with no options. Clicked Ok and the schematic and board look better.
