#include "FrSkySportSensor.h"
#include "FrSkySportSensorFcs.h"
#include "FrSkySportSensorFlvss.h"
#include "FrSkySportSensorGps.h"
#include "FrSkySportSensorRpm.h"
#include "FrSkySportSensorVario.h"
#include "FrSkySportSingleWireSerial.h"
#include "FrSkySportTelemetry.h"
#if !defined(__MK20DX128__) && !defined(__MK20DX256__)
#include "SoftwareSerial.h"
#endif
FrSkySportSensorFcs fcs; // Create FCS sensor with default ID
FrSkySportSensorFlvss flvss1; // Create FLVSS sensor with default ID
FrSkySportSensorFlvss flvss2(FrSkySportSensor::ID15); // Create FLVSS sensor with given ID
FrSkySportSensorGps gps; // Create GPS sensor with default ID
FrSkySportSensorRpm rpm; // Create RPM sensor with default ID
FrSkySportSensorVario vario; // Create Variometer sensor with default ID
FrSkySportTelemetry telemetry; // Create Variometer telemetry object
void setup()
// Configure the telemetry serial port and sensors (remember to use & to specify a pointer to sensor)
#if defined(__MK20DX128__) || defined(__MK20DX256__)
telemetry.begin(FrSkySportSingleWireSerial::SERIAL_3, &fcs, &flvss1, &flvss2, &gps, &rpm, &vario);
#else
telemetry.begin(FrSkySportSingleWireSerial::SOFT_SERIAL_PIN_12, &fcs, &flvss1, &flvss2, &gps, &rpm, &vario);
#endif
void loop()
// Set current/voltage sensor (FCS) data
// (set Voltage source to FAS in menu to use this data for battery voltage,
// set Current source to FAS in menu to use this data for current readins)
fcs.setData(25.3, // Current consumption in amps
12.6); // Battery voltage in volts
// Set LiPo voltage sensor (FLVSS) data (we use two sensors to simulate 8S battery
// (set Voltage source to Cells in menu to use this data for battery voltage)
flvss1.setData(4.07, 4.08, 4.09, 4.10, 4.11, 4.12); // Cell voltages in volts (cells 1-6)
flvss2.setData(4.13, 4.14); // Cell voltages in volts (cells 7-8)
// Set GPS data
gps.setData(48.858289, 2.294502, // Latitude and longitude in degrees decimal (positive for N/E, negative for S/W)
245.5, // Altitude in m (can be nevative)
100.0, // Speed in m/s
90.23, // Course over ground in degrees
14, 9, 14, // Date (year - 2000, month, day)
12, 00, 00); // Time (hour, minute, second) - will be affected by timezone setings in your radio
// Set RPM/temperature sensor data
// (set number of blades to 2 in telemetry menu to get correct rpm value)
rpm.setData(200, // Rotations per minute
25.6, // Temperature #1 in degrees Celsuis (can be negative)
-7.8); // Temperature #1 in degrees Celsuis (can be negative)
// Set variometer data
// (set Variometer source to VSpd in menu to use the vertical speed data from this sensor for variometer).
vario.setData(250.5, // Altitude in Meters (can be negative)
-1.5); // Vertical speed in m/s (positive - up, negative - down)
// Send the telemetry data, note that the data will only be sent for sensors
// that are being polled at given moment
telemetry.send();
