First 3d print went fairly well, the fit is a little tight so I am going to tweak the design of the lock before I print more. You can't get these apart without basically breaking something, just what I had hoped.
A project log for Locking ball and socket gooseneck system
3D printed ball and socket joint with a quarter turn twist lock at each joint. Brick shithouse goosenecks!
