Loc-line arms:
My gooseneck:
I tested a bit and this is what I found:
Pros:
1. They are cheap, two loc-line arms cost less than $20 with shipping
2. No 3D printer required, only some tools to make a platform to mount the arms on (can be made of metal, wood, plastic, whatever).
3. They hold! Without a doubt, these arms stay exactly where they are aimed until you intentionally move them.
4. No spring back - unlike the metal coil goosenecks, the ball and socket joints have no spring back.
Cons:
1. Loc-line arms are really, really stiff. This is good if you want your arms to stay put no matter what, but it makes fine adjustments difficult because the force required to move the joints causes the entire arm to "jump" from one position to the other.
2. Loc-line arms are hard to take apart and put back together. The joints just aren't designed for frequent disassembly, they are designed to have excellent holding power. Assembly is difficult enough that they actually make a special plier-like hand tool for this purpose.
Comparison to my 3d printed gooseneck:
- My gooseneck is easier assemble / disassemble, at any time you can twist off the lock nut and take it apart to remove or change the tool on the end of the gooseneck.
- Loc-line has a stronger hold, but the hold on my gooseneck isn't bad. For instance both can hold a USB cable in place no problem.
- Loc-line requires some machining skills to mount, a hole must be drilled and an NPT thread needs to be tapped to mount the arms.
Verdict? If you have a 3D printer, try my system before you buy loc-line arms. You might be surprised at how well they work.
*Loc-line coolant arms were purchased at McMaster Carr using part number 10095K11
