Soldering - DRV8836
A project log for DRVxxxx Breakout
Breakout-boards for some of TI's motor Drivers
alexAlex 05/18/2015 at 15:252 Comments
Today my ICs have arrived. So I soldered one board. This WSON-Package is the smallest IC form factor that I have soldered so far. But the board works! For size comparison: The Capacitors are 0805 SMD types.
deʃhipu wrote 05/29/2017 at 05:10 point
This is crazy tiny stuff. Is there a thermal pad under it too? Did you solder that too?
Alex wrote 06/02/2017 at 10:20 point
yes there is a thermal pad under the IC, and it is quite important to get all the heat away from the IC. I did soldered thAt just with hot air on the pretined pad. And than a a second step the pads on the sides.
