One way of finding prime numbers is to use the Sieve of Eratosthenes. This starts with a list of all numbers 2-n. You find the first number in the list, which is prime, then remove all of its multiples from the list. Then repeat.
This is advantageous on an embedded platform because it doesn't involve very much computing. The drawback is that you can't store a huge list of incremental numbers; you quickly run out of space.
The Index is the Huge Number
The solution I came up with is to use one huge number as the index for a boolean array. Basically I create an array of 32-bit integers, using as much SRAM as I have available. The sieve will read that array like so:
1. Find the first bit in the array that is a 1. The index of this bit is a prime number so print it out
2. Iterate all indices that are multiples of this prime index, setting their bit in the array to 0
3. Repeat until the array has been exhausted
Bit Banding to Save Cycles
The reason I started this afternoon adventure was to try out bit-banding. This is an address alias in the ARM core which maps to a single bit in SRAM (also works on some of the peripheral buses). This should save quite a bit of time since the alternative is a three-step process of reading the register, performing a bitwise operation to change the bit in question, then writing the register. Bit Banding can do this all in one operation.
Basic Code for Bit Banding
I'm using a Tiva C Launchpad but the bit banding feature is a part of the ARM core so this should be the same on other ARM chips. TI has been kind enough to include a macro that does all of the heaving lifting. This wasn't readily apparent to me at first so I was trying to do the offsetting mentioned in TI's datasheet which is much more convoluted. The macro method is dead simple:
//#######Bit Band Write Operation HWREGBITW(&targeRegister,targetBit) = 0; //#######Bit Band Read Operation myVar = HWREGBITW(&targeRegister,targetBit);<br>
#define HWREGBITW(x, b) HWREG(((uint32_t)(x) & 0xF0000000) | 0x02000000 | (((uint32_t)(x) & 0x000FFFFF) << 5) | ((b) << 2))
Mike Szczys
Ed S
It's the same reason there is no USB device/host support for the Tiva Launchpad in Energia, the licensing for the USB library precludes adding it to a "Viral" open source project. WTF is "Viral" supposed to mean, and why would TI put out an awesome, inexpensive, project board and then restrict the crowd that they want to use it from actually doing so in the manner in which they are accustomed to with every other development board out there.... Very frustrating.
