I got just over six months of life before having to replace the batteries. It's possible I'll get more with a fresh set because the original ones were mixed (different brands) and when I checked them at removal one was open - so maybe a weak cell to start.
One mechanical problem: the battery clips are junk. They aren't spring steel and I found that over time the clips would relax and the unit would stop working. Also if it gets dropped the battery mass is enough to bend the clip contacts. I had to open the case a few times thru the 6-month period to correct this. If I build more I'll switch to a higher quality clip.
Other than that it works great and, comparing to my phone's weather widget, it's been accurate to +/- 1C.
