![](https://cdn.hackaday.io/images/7832591519003138159.jpg)
Test fitting the print into the knob. It was a tight fit. I sanded the edges a bit to get it to fit snugly, but there was a problem with the measurements that caused it to be off.
![](https://cdn.hackaday.io/images/2161851519003278879.jpg)
Here you can see there is a 1 mm gap on the flat side of the insert.
A project log for 2001 Honda Odyssey AC Knob Repair
Using 3d printing to repair an AC knob for a 2001 Honda Odyssey.
