Monitor
I have updated my monitor program, with some additional commands and it is more of a command line style rather than single letter commands:
Command | Description |
DIR | Directory listing |
LOAD <addr> <file> | Load from address <addr> the file <file> |
OPEN <file> | Open the file <file> and output to the current output device |
MEMTYPE V | M | Set memory type to VRAM (V) or normal memory (M) all memory commands act on this memory type |
SET <addr> <xx>* | Set the memory from address <addr> to bytes defined in <xx>. A sequence of more than one byte can be written. |
DUMP <addr> | Dumps 8 byte blocks from address <addr> with an ASCII readout. Enter continues the dump for another 8 byte block, any other key stops the dump. |
WATCH <addr>* | Watches the memory at <addr>, outputting bytes to the output device until any key is pressed. More than one address can be watched. |
SECTOR <addr> | Load sector <addr> in to memory. Useful for low level inspection of SD cards. |
