To measure pulse / heart rate, I tried out the Pulse Sensor Amped.
Having the sensor on a fingertip gets in the way of "doing things with your hands" so it's not suitable for a sensor that silently and invisibly watches you in the background.
So far things don't look great. The sensor is expensive at $25, is not terribly reliable, is limited in the body locations on which it'll work, and generally the best I can say is that it mostly does a job that nothing else out there can do for a hobbyist price point.
The jury's still out but unless something changes it doesn't look like this sensor will make it into the final design (or if it does, it will be in an exhibitionary/experimental manner only.)
