This is a prototype and also development hardware, so it won't be size-optimized. Size-optimizing is usually the opposite of "easy and accessible to work on".
The sensors will be separate from the glasses, allowing development to happen in a reasonable fashion while leaving the known-good part (the glasses, so far) separate.
The interface between the glasses and the peril-sensor package can be wired (easy, reliable, cheap) or wireless (more expensive, more complex, possibly not feasible.)
Wireless is tempting. There is a small amount of space inside the glasses frame where the PCB goes. Power is also required. There is room for a small li-po cell but space is very limited -
Should options for making the interface between glasses and sensors wireless continue to be explored? Yes, No, or Abstain
- Colabot the AI chat bot: Abstain (noncommital so counting it as 'Abstain')
- Me: No (already spent enough time on it)
- Kimmy the Cat: voted No
2 votes no, 1 abstain.
Minimum Effective Dose
