PIL is a deprecate Python library. In order to keep the 'OscScreenGrabLAN.py' script compatible with current and future versions of Python 2, for both Windows and Linux, from now on the script is using 'pillow' library instead of 'PIL'.
If you already have 'PIL' installed, it MUST be uninstalled before installing 'pillow'.
The updated version of the 'OscScreenGrabLAN.py' and installation steps for Python and 'pillow' can be found at https://github.com/RoGeorge/DS1054Z_screen_capture
