A project log for FabScan Pi - 3D Laser Scanner
FabScan PI is a Stand-Alone Web-Enabled Raspberry Pi based Open-Source 3D Laser Scanner
We are working on a new FabScanPi enclosure. It is discussed at the FabScan google group.
Furthermore there is a drawing of the needed dimensions in this section: http://mariolukas.github.io/FabScanPi-Server/software/#config-file-values
You can find the laser cut files in different formats here: https://github.com/mariolukas/FabScan-Case/tree/master/current
where can I get the dimensions from to make the box myself?
Yes, delete it Cancel
