The new version is almost ready. I changed a lot of fronted stuff. Some major bugs are fixed. Finally i also finished the MeshLab integration. The FabScanPi is now able to generate meshes of the point clouds. But that is not enough... you are able to generate textured meshes within the new version.
Here are some screenshots.
Object which was scanned.
Textured Mesh of the Scan.
Textured Scan of our famous FabScan Bear.
