Shortly after introducing rearranged PCB layout for nodes, I realized
that I use LiPo batteries in all my battery powered nodes. That is
making no use of the step up capabilities of the DC to DC converter.
When designing it I was wanting to have possibility to run the nodes
from variety of batteries. But it was never happened. In fact I have
ordered some $3 to $5 LiPo batteries from eBay that supposed to be used
for quadrocopters. These, although labelled RC 25C batteries, have
battery protection electronic mounted on them (DW01+FS8205). My first
happiness soon faded when I checked it does not stop the battery from
under voltage. It will probably need some more investigation. Never the
less, for the price, they seems like a nice choice for compact (43mm x
24mm x 9.5mm) power source and claiming ~720mAh of capacity (it really
depends on supplier, ranging from 600 to 700mAh).
This led me to consolidation of what I use in case of LiPo powered node, and I ended up with new design of battery power circuit. I have taken out the DC to DC part and added low drop out linear regulator. MCP1700 with excellent quiescent current and drop voltage less then 200mV. I would lost the step up capability, but LiPo operate best in ranges of 4.2V to 3.4V as shown on the picture. Perfect match for such use. Taking a calculator in hand and the datasheet it revels, that the difference in terms of efficiency for LiPo battery is negligible. And in fact as the LiPo discharge it is more convenient to use liner regulator instead of switching, making it more energy efficient! Then single look on quiescent current makes the choice inevitable, linear consumes ~2uA while switching consumes ~80uA. That is 3 times more to what my ATmega328P@16MHz consumes while sleeping.
While having battery type set, it is much easier to choose charger circuity. Looking for easy solution I found MCP 73832 a single cell Li-Ion/Li-Po charge management controller. It is small footprint linear charger with charge current programmable by single resistor from 15 mA to 500 mA. Again datasheet stated very low standby current, and it seems to be used in many designs as Google reveals.
I ended up with new version of PCB and called simply node version 1.4. It has micro USB connector for power or charging and charge current set to ~450mA. With a rule of thumb of 1C charging current, it allow use of any Li-Ion or Li-Po battery with capacity bigger then 450mAh. It has no load sharing, but sleeping ATmega is not a problem. I have switched to blue solder mask colour and it is alrady tested and available for sale in my online shop.
I have measured power consumption in various stages to see how it behaves. Where there is range present it is difference between 3.5 and 4.2 input voltage.
... more on blog.
