PCB arrived on Monday and Tuesday I put it together. Say it short, it works. Happy again, I can continue with testing of new gateway. The differential pairs design worked, and the 33R dumping resistors are not required. Moving 3V3 power line out of RX and TX pairs probably also. Results is having a nice 2,5x5 cm breadboard friendly W5500 board. I will put PCB and finished version also to BUY section on right side. Maybe someone is interested.
http://openhomesecurity.blogspot.cz/2016/07/w5500-test-pcb-progress.html
