Gateway PCB is in fabrication, and I'm hoping for the best that there
will be no errors on PCB. It will have following parameters:
- MCU ATmega1284P, 16KB RAM, 128KB Flash.
- 8 analogue inputs for balanced PIR sensors.
- 4 digital inputs for simple sensors, like door/window reed switches.
- 1 box tamper input.
- TWI/I2S expansion connector for up to 4 additional 8 channel analog inputs.
- 2 relay outputs with selectable 12V power out.
- RS485 protected interface for wired nodes.
- RFM69HW for wireless nodes and sensors, pigtail and rubber antenna.
- W5500 10/100Mbps Ethernet for web interface and MQTT.
- SIM900 GSM modem for SMS alerting, pigtail and rubber antenna.
- RTC clock with separate battery backup with NTP synchronization.
- 512kb EEPROM as logger
- Power Off and Empty battery inputs.
- Standard FTDI Arduino programming interface.
I have been so bold that I put it on pre-order in the BUY section for 72EUR or 79USD.
