After connecting GSM modem and creating some functions to interact with it, I have found that the wiz820io is not recovering correctly on power failure. There is needed to reset it after power on. Sadly I have connected the reset of atmega to wiz820io. Now I'm investigating to use the Ethernet INT signal that is not used as separate reset or to add a watchdog chip to the board.
