There is now new board available called Node 1.3. It is small evolution
of previous version 1.2. Mainly there are changes in IO Header pinout
and possibility to add thermometer based on MCP7900A.
MC7900A is linear active thermistor IC. That is analogue temperature
sensor that converts temperature to analogue voltage. It’s a low-power
sensor consuming 6 μA (typical operating current). And with little bit
of calibration at room temperature it can provide ±0.5°C from 0°C to
+70°C accuracy. Other then that some labelling was added and footprint
of RS485 connector have changed.
