WHY ?
Why I want to develop this device?
Because currently I am renovating may flat and I am going to mount LED panels and LED strips in ceiling. And I want to control them through smartphone + wall switch. I could not find a normal solution which could satisfy my wishes + dim LED panels from 0 .. 100% with small steps !
THE MAIN TECHNICAL REQUIREMENTS
- Drive LED panels
- Switch them ON/OFF
- Dim them using PWM
- Dim from 0 .. 100% ( step 1% or less)
- LED panel maximum power 25 W
- Drive RGB or White LED Strips
- Control individual channel - 3x channels ( red, green, blue)
- Get at least 100W from all channels together
- Supply input
- Use standardised power supplies
- Supply device from 12 V DC
- Functionality
- The main control possibility must be wall switches
- Additional control possibility must be control via electronic device like - PLC, raspbery pi, smartphone etc.
- Devices must act as a MASTERS and SLAVES
- MASTER must control, drive other SLAVES
- 1 MASTER creates lighting zona, SLAVES drive own outputs according to the master output ( similar like when DMX512 two devices has the same address )
- Control
- Using wall buttons, rotary encoder, presence sensor
- 1. ONE position spring tape switch -> on/off
- 2. TWO position spring tape switch Up/Down -> dim up/down
- 3. TWO position spring tape switch Up/Down + ONE down spring tape switch -> dim up/down + turn on/off
- 4. Rotary knob with encoder and button -> dim up/down + switch on/off
- 5. presence sensor -> on/off
- * from 1. to 4. cases presence sensor can be used additionally ONLY to turn lighting OFF if there is no movement more then 30 min. As if you forgot to switch lights off!
- Through smartphone
- Similar functionality like with buttons
Raphaël Maginot
Should muse to offer this as service with ownership retained, strict term contract, deposit, and billed monthly. Who wouldn't want to finance this?
