The menu system is done. Time to switch gears and start on the hardware. (Which I hope the mailman brings to me today). I need to prototype the following
Temp sensor /Humidity
Optoisolator with relays
Speaker /w Amp
Microphone
PIR sensor
Then move to the ESP8266 and do the security alarm sensors plus a few more relays to control outlets.
I need to do the cost analysis on either doing every outlet (one plug per) or just doing certain ones based on usage. Not doing both outlets because who wants to plug the vacuum in and then pull out the phone to turn it on?
edit: forgot the cheesy photo of the menu before I skin it:
john jensen
