Parts
05/20/2015 at 19:48 • 0 commentsGot the touch screen in. Started checking out my test code for debounce functions to ensure proper touch recording.
Going to fire up gimp and do the control bitmaps. I will be using different screens for each the controlled items.
The plan is to have a default menu for the first screen, Each of the options will take you to a screen to control that item. Using a bitmap that is stored on the micro sd card. Then detecting where the user pressed to change the item.
Still need to do software control of the backlight. To save power it will have a timeout to shut off the screen and sleep the controller. Upon press of the screen it will wake the controller .
