Here is some code to monitor the status of the VPN server. The RGB LEDs are common anode, with the anode connected to 3.3V (and a 100Ohm resistor on each leg connected to GPIO). The ESP module sinks the current:
LED on - gpio.write(3, gpio.LOW)
LED off - gpio.write(3, gpio.HIGH)
This is so the modules still boot without going into bootloader mode, while keeping the resistor values quite small (brighter LEDs).Unfortunately because the ESP01 module only has two GPIOs, it is difficult to add both button and LED functionality at the same time. I will break these connections out later. But for the moment, the button is connected to GPIO 3 and the LED to GPIO 4.
The button is connected as follows:
VCC +-+-+ | | +-+-+ | | |10K| | | +-+-+ | | +-------+ | GPIO ------+ 100 +------+ +-------+ | + \ Switch \ + | +---+ +-+ + GND
The code:
function vpnconnect ()
conn=net.createConnection(net.TCP, 0)
conn:on("receive", function(sck, c)
if string.find(c,"CONNECTED") then
print("Connected")
state = 1
--gpio.write(3, gpio.HIGH)
gpio.write(4, gpio.LOW)
end
if string.find(c,"RECONNECTING") then
print("Standby")
gpio.write(4, gpio.HIGH)
state = 0
end
if string.find(c,"AUTH") then
print("Auth")
state = 1
--gpio.write(3, gpio.LOW)
end
end
conn:on("disconnection", function(sck, c)
print("VPN Disabled")
connected = 0
end
end
function buttonpress (level)
if triggered == 0 then
if level == 0 then
if connected == 1 then
triggered = 1
tmr.alarm(1, 200, 0, function() --debounce delay
if state == 0 then
conn:send("hold off\r\n hold release\r\n")
state = 1
else
conn:send("hold on\r\n signal SIGHUP\r\n")
state = 0
end
triggered = 0
end
end
end
end
end
--Currently using GPIO3 as button, all LED references commented out
--gpio.mode(3, gpio.OUTPUT)
gpio.mode(3,gpio.INT)
gpio.mode(4, gpio.OUTPUT)
connected = 0
state = 0
triggered = 0
gpio.trig(3, "down", buttonpress)
tmr.alarm(0, 1000, 1, function()
if connected == 0 then
vpnconnect()
conn:connect(7505,"192.168.1.1")
connected = 1
end
conn:send("state\r\n")
end
end
Note that when the VPN is in "standby", the service is still running, it just changes the IP tables so the VPN is no longer used. The service daemon will report that it is still running.
You can use LuaLoader to save the file to the ESP module so it runs on boot.
To stop it while testing just run:
tmr.stop(0)
conn:close()
