Updated init.lua for the PCB with the Osram LED:
function vpnconnect ()
conn=net.createConnection(net.TCP, 0)
conn:on("receive", function(sck, c)
if string.find(c,"CONNECTED") then
print("Connected")
state = 1
gpio.write(5, gpio.HIGH) --RED
gpio.write(6, gpio.LOW) --GREEN
gpio.write(7, gpio.HIGH) --BLUE
end
if string.find(c,"RECONNECTING") then
print("Standby")
gpio.write(6, gpio.HIGH) --GREEN
gpio.write(7, gpio.LOW) --BLUE
state = 0
end
if string.find(c,"AUTH") then
print("Auth")
state = 1
gpio.write(5, gpio.LOW) --RED
end
end
conn:on("disconnection", function(sck, c)
print("VPN Disabled")
connected = 0
end
end
function buttonpress (level)
if triggered == 0 then
if level == 0 then
if connected == 1 then
triggered = 1
tmr.alarm(1, 200, 0, function() --debounce delay
if state == 0 then
conn:send("hold off\r\n hold release\r\n")
state = 1
else
conn:send("hold on\r\n signal SIGHUP\r\n")
state = 0
end
triggered = 0
end
end
end
end
end
--Don't forget to associate with AP with (once off) commands:
--wifi.setmode(wifi.STATION)
--wifi.sta.config("accesspointname","yourpassword")
--wifi.sta.connect()
--print(wifi.sta.status()) <--5 means associated
--print(wifi.sta.getip())
gpio.mode(4,gpio.INT)
gpio.mode(5, gpio.OUTPUT) --RED
gpio.mode(6, gpio.OUTPUT) --GREEN
gpio.mode(7, gpio.OUTPUT) --BLUE
--Set output low to turn on LED
connected = 0
state = 0
triggered = 0
gpio.trig(4, "down", buttonpress)
tmr.alarm(0, 1000, 1, function()
if connected == 0 then
vpnconnect()
conn:connect(7505,"192.168.1.1")
connected = 1
end
conn:send("state\r\n")
end
end
