I hand out a lot of Hackaday stickers when I'm at events. This will allow me to hand out even more stickers
I have all the parts printed, the magazine is assembled, and the motors are installed. I figured it would be a good time to test out the sticker slinging mechanism. It works, and it sounds like bees.
This is really only half the gun. I'm especially proud of the magazine. Here's how the entire gun works:
Pretty pictures:
Now it's time to integrate everything and make it work. If the project is going to fail, it's going to fail here.
I still have a week or two until the HobbyKing order comes in, so until then it's time to model the mechanicals. I'm pretty much done with that:
That's what the entire gun is going to look like. It's somewhat cleverly designed, with the grip modeled as a mirror of itself:
The holes in the front are for these cool little tact switches from adafruit. LiPo battery sits behind that, and the entire thing screws together.
Of course all of this work is pointless until I can get those little quadcopter motors. I'll start printing this out in the mean time, and once those motors come I'll be launching stickers across my basement. Fun times.
Oh, I put these models in Cura. It looks like ~= 40 hours to print everything.
I've had a few people ask me how this thing will work. First, a picture:
Yeah, holy crap, OpenSCAD does colors.
So, in this image, the yellow parts are 3D printed. The light blue is a 9g servo, the purple parts are brushless outrunners designed for quadcopters, and the dark blue parts are grippy feeder things that are printed out of ninjaflex and attached to the outrunners.
The servo, and it's accompanying grippy feeder are set slightly forward of the outrunners. This servo will grab a sticker from the magazine and feed it, with the help of a semi-circular ramp, to the outrunners. From there, the motors - spinning at a very high RPM - will launch the sticker out of the barrel.
So it's pretty much a baseball pitching machine that you'd find in a batting cage.
The Stickers are here, and that's the scale of them with a US quarter, nickle, and a bic lighter. Yes, they're small
To shoot these things through a pair of flywheels, I need to know how thick they are. Here's some measurements:
24 stickers / 9.40mm = 0.392mm
24 stickers / 9.42 mm = 0.393mm
20 stickers / 7.82mm = 0.391mm
17 stickers / 6.66mm = 0.392mm
13 stickers / 5.07mm = 0.390mm
I'm guessing the separation between the flywheels should be around 0.38mm. The flywheels will be make out of a squishy material, anyway.
I've finished the most dangerous part of the sticker gun: the part that holds the quadcopter motors. Just need to print it out:
Apart from some wire and pushbuttons, that's it. Everything else, except for a handgun spring and some screws, will be 3D printed.
Oh, I found a guide for converting those servos to continuous rotation. That'll be handy.
I'm noticing a severe lack of coolness when I hand out hackaday stickers at events. I need a gun. A gun that shoots stickers at people.
The basic idea is something like one of those Nerf gun disk shooters that use a small DC motor to shoot foam discs. It's somewhat loud - thus cool - and they can shoot pretty far. I'll go with something like that.
Ammo will be 1" round stickers from stickermule. They need to be round for obvious reasons, and we're already using stickermule for hackaday stickers. Here's what they'll look like:
That'll only be 1" in diameter. Small. very small, but that's what you get when you need a ton of cheap ammo.
Files in the github, although right now that's just a test jig for the magazine. Three lines of openscad.
Oh, I'll be using a 2300KV brushless motor to shoot the stickers out and a 2 cell LiPo to power it. That's 17,000 RPM. Holy crap.
This is a great project, not sure I get how it works - is it just two flywheels like the ball machine at a batting cage? Consider designing o-ring grooves on your flywheels and using o-rings to actually contact the sticker. This will grip better and will be more forgiving on fit because they will compress and allow for a generous interference fit.
Yeah, it's pretty much a ball machine in a batting cage. I'm going to be printing some flywheels to fit over a brushless outrunner. Ninjaflex, because it's grippy, and printed because I can get the fit *just* right.
why not stickers and beer coasters? We would need a hackaday IPA to use those coasters with, and it can be an open source recipe!
stick the disc on magnetic back , addressing Mr. Szczys idea and adding fridge bling , viva los nerd
Can we get stickers backed with poster board? I would imaging this would greatly increase the distance of the flying swag.
And would upgrade us from paper cuts to linear welts!
( beer) coaster gun Or button gun may be possible - make it modular :D
Don Juan De Pyro
Andrew Schreiber
Nathan Brown
Next step Shuriken (Ninja throwing stars)...
