The new arms are made of 10mm plywood instead of 4mm in the first version. The frame itself is made of 6mm plywood.
![](https://cdn.hackaday.io/images/8614711437504494944.jpg)
![](https://cdn.hackaday.io/images/4464341437504441028.jpg)
![](https://cdn.hackaday.io/images/5718871437504466795.jpg)
The arms can be collapsed. So you can pack the copter to save space.
