Seeds began germinating in The Smart Garden Mini at 6:30 P.M on June 5th, 2015. The Arduino program logged the internal temperature, water level, and light levels of the plant to an SD card. The outside temperature in Chicago as of 3:30 A.M was 51 degrees. The internal temperature of The Smart Garden Mini at 3:30 A.M was 76 degrees.
Also...Hydroponic rocks are being used to grow the tomato plant.
